Bizhub C454 D390 error
  • Jabes
    • Jul 2015
    • 6
    [Error Code] Bizhub C454 D390 error
    Hello guys, i'm new at the forum, i'm not technical and I need very help of yours
    I am with serious problems with a bizhub c454. The machine suffered a electrical short circuit that damaged the PWB Board and the HD.
    We buy and installed a new board and HD, the machine starts normally, but, shows the Trouble Code D390.
    I believe that need install the firmware of the machine, i have all versions on my PC.
    I did not succeed help technical here on Brazil, I am willing to pay to who help me. If necessary, i make access remote and facetime.
    Sorry my english, i'm bad.
  • allan
    RTFM!!
    • 5459
    Re: Bizhub C454 D390 error
    Did you use the old SSD(small removable board with memory chip on it) from the MFPB you changed. It is a check sum error.
    Does the machine give restore option on the screen? It does give CD390 when you change the MFPB with a new one. That is normal.
    After that you must input the machine type information.
    Whatever
    • Jabes
      • Jul 2015
      • 6
      Thanks for your reply allan!
      So, the machine shows the option "Recover Data", but the touch panel doesn't accept commands, only the buttons and the keypad are responding.
      • allan
        RTFM!!
        • 5459
        Reseat all the connectors on the MFPB and the supply.
        Whatever
        • tech51
          • 846
          Install the latest firmware and then re boot the machine. If this code comes back the machine should re boot itself anything up to 3 times. You have to let it do this. After the last boot the recovery button should work.
          • Jabes
            • Jul 2015
            • 6
            The problem persists
