File Management Utility
  • ClarkIR
    • Oct 2013
    • 74
    anyone ever use this before? I assume it redirects files to folders based on a specific variable (ie the filter). Is this accurate? I can scan to the receiving folder but can't seem to set up a correct distribution rule to redirect the file to the target destination. Anyone smarter than I care to tell me how this works. The manual is vague to me and I do better with less ambiguous direction.
    • 22920
    Re: File Management Utility
    Do you mean the Scanner File Utility, Scan to File Utility or SFU? Essentially the SFU connects your MFP to a server via FTP (file transfer protocol). Personally I prefer to use SMB (server message block protocol) when scanning to file from a Kyocera, which does not require the utility. If you prefer FTP, you can use any FTP utility (like Filezilla). They all do basically the same thing. The Kyocera utility prompts you through the setup, so it's a little friendlier for the less experienced installer.
    After a little checking it appears that they've renamed the SFU to FMU, but it's basically the same thing. =^..^=
    • ClarkIR
      • Oct 2013
      • 74
      I meant the file management utility... None of those are that.
      • ClarkIR
        • Oct 2013
        • 74
        Its not even close to the same thing, seeing as you can operate multiple mfp's from one program and set up distribution rules.
        Listen if you don't know anything about it just move along. I don't need you here trying to correct me because you don't know what I am asking about.
          • 22920
          I consider myself corrected. =^..^=
          • tmaged
            Owner/Service Manager
            • Oct 2008
            • 1857
            Snarky
            Hope that helps !
            -Tony
            www.dtios.com
            Become a fan on Facebook
            • subaro
              • Oct 2010
              • 1273
              ClarkIR . You are just being too irrational quickly. This forum is not where g d lives and provide perfect answers. People throw out ideas as to try and help. sometimes they are bang on and sometimes not. You could have said something different i am sure. just to quick to the draw. all he is doing is putting out ideas for you and if you are not contented, then call kyocera tech support.
              • ZOOTECH
                Senior member of CRS
                • 3378
                Green card to red card in one post -nice.
                • NeoMatrix
                  Senior Tech.
                  • 3514
                  We've already picked up on your frustration,no need to express that any further to the forum. If you set your ego aside we can no doubt assit you further with what you ask. Explain to the forum your particular scenario.Example:You have TA 181,250,300,500's connected to a network. You can scan to XYZ machine but you cannot forward to PC'c at local A,B,C locations????? The more information you tell us the more we can work out where your at. Don't forget this is an international forum. The wording you use may not be the same wording or functional explanation as used in other countries.
                  • ClarkIR
                    • Oct 2013
                    • 74
                    Already explained what I needed help with and someone who didn't know anything about what I was asking instead felt the need to correct me twice. It's frustrating to have someone tell you you have no idea what you mean when despite the fact they apparently haven't touched the software
                    • ZOOTECH
                      • 3378
                      BC has always tried to help from his vast database, try not to diss someone who is trying to help you.
                      • NeoMatrix
                        Senior Tech.
                        • 3514
                        ..... Is the file manager utility external software eg TA181.Kyocera install disc..... Is the file manager utility on a server ?..... Is the file manager utility on the MFD console?.... ..... more info......
                        • subaro
                          • Oct 2010
                          • 1273
                          for all those intrested in this utility, here is a link to download the manual and look it over. not many pages.
                          http://cdn.kyostatics.net/dlc/gb/documentation/usermanual/file_management_utility.-downloadcenteritem-Single-File.downloadcenteritem.tmp/File%20Management%20..._(Rev.2)_ENG.pdf
                          please advise or correct if this is not the utility in question.
                          • ClarkIR
                            • Oct 2013
                            • 74
                            Its not obvious but my first message was in response to his initial comment. Then he edited his post and put in the thing I quoted in the subsequent reply. So it looks to you like I am being impatient but it's actually consecutive replies to someone who just felt the need to tell me what I really meant and then edited their post to validate their opinion.
                            im sorry if that comes off as brash but it's just frustrating to have someone try and correct you without like even knowing what I am talking about. I'm not sure how anyone would not be a little miffed by that
                            • ClarkIR
                              • Oct 2013
                              • 74
                              if he didn't know what it was he should not reply or just say he doesn't know as opposed to the initial line he took. I understand people take his word as gospel because he is very knowledgeable so if he just writes it off as being another sfu then everyone thinks the answer is given and no need to respond.
