How can I after replacing the entire PM kit MK-701 reset screen warning to replace the MK kit? I think I made the mistake of not unplugging the unit when pm was done so normal way/chip or fuse on nit didnt reset it.
FS9530 Reset "Replace MK"
Tags: None
Re: FS9530 Reset "Replace MK"
No, I don't think that you made a mistake. You need to send a PreScribe command to reset the PM indicator. I'll attach those commands tonight. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^= -
We also have a FS-9500 that says "Replace MK-701 kit" an warning. If the mentioned way will work with that or not please detail...Comment
It should be the same. Here is the command:
For developing unit: !R! KCFG "LFRE","DEVK",0;EXIT; Note: any value can be set, not just 0.
For drum unit: !R! KCFG "LFRE","DRUM",0;EXIT; Note: any value can be set, not just 0.
For fuser unit: !R! KCFG "LFRE","FUSR",0;EXIT; Note: any value can be set, not just 0.
blackcat: Master Of The Obvious =^..^=Comment
Thank you, I saw that mentioned in another post. But no details how to do it. Please post how to use theseComment
There are several answers in this post: http://www.copytechnet.com/forums/ky...tre-login.html
LPR Jar has not survived the transition into Win8. I still use my old WinXP laptop just for this purpose, with a surviving functional copy of LPR Jar. Note: Use care if you search the interwebs for LPR Jar. I accidentally downloaded a persistent virus that continues to raise it's ugly head occasionally.
The FS-9500 will be the simplest for you. It still has the Printable Data link on the web interface. Just type or copy the command to the Printable Data line and Start. Or you can direct to a Textpad or Notepad file.
The FS-9530 will require you to load some software. Either KMNet Viewer, IC Link, or a print driver combined with the Command Prompt. =^..^=If you'd like a serious answer to your request:
