TaskAlfa 356ci Command Centre
  • stickfly
    • Jun 2010
    • 30
    Hi,
    Yesterday I tried to log into the web interface on a Taskalfa 356ci to check the network settings. I did this with my laptop connected directly to the machine using a crossover cable as usual.
    I put the IP address into the address bar of Chrome but nothing. Chrome just kept going to its home page. So I tried Firefox but Firefox would not open Command Centre either. I just kept getting a message saying : Screenshot 2016-04-25 12.53.57.jpg
    Is it possible that there is a setting to turn off the web interface as we could open Command Centre when setting the machine up a week ago, but since then an external IT guy has been setting up the scanning for this machine. Has he changed something ?
    Many thanks ...... G
  • correo.tony
    • 72
    Re: TaskAlfa 356ci Command Centre
    Hy !!
    yes, in all KYOCERA multifunctionals Command Center you can block or filter TCP/IP traffic by IP ranges :
    Protocolos
    1 0.0.0.0 0.0.0.0 HTTP
    LPD FTP IPP
    HTTP SNMP RAW Port
    the external IT tech is a lovely man !!!
    you can configure this filters in TCP/IP Protocols, and after in IP Filters menu,
    execute SIM U021 and configure all another time and after change the Command Center pass !!
    Bye !!
    • Kyo fan
      • Dec 2013
      • 368
      What correo.tony said could be the case. But it also could be (since you are connecting directly to the device) that you haven't properly configured network adapter settings on your laptop so you can't reach machine's ip address.
