Copystar is Kyocera?
  • padre
    Hi, Is Copystar part of Kyocera? I've heard of Kyocera printers for many years but recently had someone quote a price on a Copystar. Just trying to understand the difference/relationship between Kyocera and Copystar. Thanks, padre
  • HmkPrinterTech
    • Sep 2008
    • 21
    From what I can tell, they are one and the same.
    • kyoceradude
      The Great Gazoo
      • Aug 2006
      • 442
      Copy Star is another part of Kyocera. Not all toner is interchangable between the two. Each has its own supplies.
      My mission here on Earth is to help all you Dum-Dums!
      • 10871087
        • Jan 2005
        • 1143
        Yup, that's about it. back in the day the features were a little different but for the past few generations of machines everything is the same except the toner cartridge and the name on the front door.
        Copystar MFP's less then 30 PPM are also available via a "distribution chanel" in the US and Kyocera MFP's are strictly dealer based.
        • copydr
          • Jan 2008
          • 6
          Yes, Copystar is a division of Kyocera.
            • 22921
            The print drivers are slightly different also. If you load a Kyocera driver to a Copystar, or a Copystar driver to a Kyocera you lose some of the functionality including the Auto Configure function. =^..^=
