Problem with first 2 or 3 pages in a set not jogged properly when stapling with 3 hole punch or when offsetting 3 hole punch sets without staples. Staple only or straight stacking 3 hole punch sets are perfectly aligned. The DF790 is attached to a 8000i and has the newest firmware installed. The worst case is when there are 2 pages in the set, page 1 is 5 mm away from the paper stop when stapled. This is very consistent. It appears to be due to the timing of the paper when sheet 1 goes around the large roller and meets up with page 2. The jogging paddles can not adjust the first page as it enters the processing tray with page 2 on top of it.
I have update firmware, installed new jogger blade A, tried finisher control board, punch control board, punch unit, swapped out 2 of the transport motors & removed the large roller assy to make sure there was nothing for the holes to catch on in the area.(what a job) Thought it might be a dirty sensor but works perfect when not punching the pages; cleaned them any way.
Any ideas out there???
