Kyocera FS-3640MFP continual adding toner message
  • copiertec
    • Jan 2016
    • 2184
    I have a Kyocera FS-3640MFP with a continual "adding toner" message, I removed the right cover and everything appears to be in place all the motors and gears seem to be turning. To rule out a maintenance kit, I took the developer unit and drum unit and swapped them into a 3540MFP and they work ( a little over-toned),however, no adding toner message. I took the FS-3540mfp drum and developing units and placed them into the FS-3640mfp and the continual "adding toner" message is on the LCD screen. The firmware I believe is current 0514 and no error massages. I did not see any tech bulletins. Any ideas?
  • copiertec
    • Jan 2016
    • 2184
    Re: Kyocera FS-3640MFP continual adding toner message
    I brought it back to the shop and watched it for about 30 min stuck in that "adding toner" cycle. It basically fills the toner waste bottle while in the process. I'm thinking possibly main board issue.
    • tmaged
      Owner/Service Manager
      • Oct 2008
      • 1855
      Is the drum coated in toner ? That ususally indicates some type of high voltage arcing. I was going to suggest looking at U130, but it doesn't look like it has that maintenance item.
      Hope that helps !
      -Tony
      www.dtios.com
      Become a fan on Facebook
      • copiertec
        • Jan 2016
        • 2184
        The drum looks good, I turn off the mfp, pull out the drum unit and it looks good, not covered in toner. The drum only has 24k on it. I tried a drum and developer refresh to no avail, No 130.
        • mita
          • Sep 2010
          • 87
          Don't know if this is what you have but it may help QA B379-2MC-0003. if you have access to the kda service portal.
          • copiertec
            • Jan 2016
            • 2184
            My company has access to KDAconnect and can't find that bulletin under the FS-3640MFP. What does it pertain to?
            • mita
              • Sep 2010
              • 87
              • copiertec
                • Jan 2016
                • 2184
                What measure is taken to change the toner level detection? It talks about it in your post, however, it does not explain how to change the toner level detection.
                • mita
                  • Sep 2010
                  • 87
                  Sorry I should have said it is a firmware update to correct the issue
                  • copiertec
                    • Jan 2016
                    • 2184
                    NP, I believe it has the latest firmware 0514. I tried a main board swap, however, the EPROM is soldered on the board and I get 180 error code.
                    • darry1322
                      • Oct 2010
                      • 817
                      After changing the main board you'll get the C0180 code. Go into MM004 to clear the 0180 code.
                      • copiertec
                        • Jan 2016
                        • 2184
                        After replacing Main Board we still have the issue. Back to the drawing board.
                        • copiertec
                          • Jan 2016
                          • 2184
                          Retracing all of my steps, I believe the issue started after performing U002 (resetting factory default data). I have used this mode on other models and have not had any issues. I'm wondering if it lost rom data from the factory and has no reference point for toner?
                          • Kyo fan
                            • Dec 2013
                            • 368
                            It will do the toner initial adding if you performed U002. You will have to wait for it to finish. There is one more thing to be checked in this case. That's the developer drive gear which breaks every now and then:
                            • copiertec
                              • Jan 2016
                              • 2184
                              [ATTACH=CONFIG]35962[/ATTACH]
                              You were spot on Kyo fan... thank you. I let it run and it came to ready.
