Hi,
Quite new to Kyocera stuff, but is it possible to have the machine send its meter readings on a specific date every month via email to me? If so, does anyone know how to do this? and also if its possible to specify a seperate SMTP server for this? (I would like to use my own company's and keep it separate to the one that the customer uses for scan to email)
The machine I want to set it up on is a TaskAlfa 306CI, and also is it possible to set up alerts for when the machine requires toner? I know there is various options available e.g Print Fleet etc but if the machine has the options built into the firmware then I would like to try these first.
If anyone can shed some light on this, that would be great!
Many Thanks
Many Thanks
