Have A TA6002i, doing smb scanning with the following settings enaled: 400x400dpi(ultra fine), PDF Quality 3, Continuous Scan, File Seperation, Border Erase, Blank Page, Auto Color/BW. Intermittently getting a Warning Low Memory error when scanning. Scanning to WIN 2012 R2 server with shared folders, using ports 139 & 445, both confirmed to be open. Problem occurs about every 2-3 days, its never occured while ive been on site. sat & watched user scan for 30+ minutes straight without an error. no error codes, just memory error.
Also, have swapped surges, patch cables, updated firmware & even swapped like machines. the account has 6 machines & 3 of them do the same thing. Only errors when using previously mentioned settings. never seems to error when just scanning with default settings.
Is there a setting that could clean the cache & temp files on the hdd, that can be scheduled for more frequently.
if anyone has any input, it would be gratefully appreciated! ive been fighting the problem for 6+ monthsKyocera Error 06-01-17.jpg
