error code c7402
  • enricokr
    • Apr 2025
    [Error Code] error code c7402
    Hello everyone I have a problem with on a kyocera M6026cdn, using a compatible toner toner, after a few copies, he started begging to make strips and abut toner, when i opened the development group and i noticed they were cracking Of crystallized toners and then I emptied the development team, I put it back, I installed an original toner but when I start the multifunction I get the C7402 error. Any one of you can help me?
    Thank you in advance
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1857
    Re: error code c7402
    Never use compatible toner in a color machine. I'd guess you'll need new DV units & some OEM toner.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • Scott
      • 189
      agree with Tmaged
      • George J
        • 107
        What do you mean by 'emptied the development team'. At minimum your cyan developer is wrecked...
        • sparkycivic
          • Apr 2017
          • 348
          "C7402 Developer C Type Mismatch Error",
          Ill guess that some sort of damage occured to an electrical connector for the Cyan DV, or maybe the prom on the DV got zapped by static.
