Waste bottle has not been replaced.
  • ntbann
    • Jan 2012
    • 623
    I have a TA3252ci that says " the waste bottle has not been replaced. Have replaced Waste unit, Firmware, And calibrated waste bottle. Problem still remains. Anyone run int this yet? thanks in advance.
  • JSC
    Gimp
    • Dec 2006
    • 618
    Re: Waste bottle has not been replaced.
    there have been a few bulletins on this, I think it can also come up with waste full when it isn't. The actuator has been redisigned, you have to remove the whole waste bel assy.
    i'll have a look in the morning for the bulletin.
    The gene pool could use a little chlorine.
    • ntbann
      • Jan 2012
      • 623
      I replaced the waste bottle unit with the new style already.
      • Kyo fan
        • Dec 2013
        • 368
        The latest firmware disables piezoelectric sensor which should solve it, unless there is something more involved in your case.
        • Tonerkiller
          • Oct 2012
          • 665
          Did you calibrate it?
          • ntbann
            • Jan 2012
            • 623
            In my original post I said I replaced the waste unit, updated firmware, and calibrated waste bottle!
            • JR2ALTA
              • Feb 2010
              • 2028
              Have you updated the firmware?
              sorry I had to, haha
              • ntbann
                • Jan 2012
                • 623
                Figured it out. U159 waste toner was set to 0. default is +20. No idea how it got changed?
