I heard the noise in the fuser section in an fs2100d printer...
I replaced the fuser... the noise was still there...
I took out the fuser... and tried to grease the spot where the gearbox peaks out of the machine body... where the gear teeth stick out... that meet the gears on the fuser...
I greased the gears on the side of the fuser... I did not dissassemble the fuser or remove any gears from fuser or go very deep with greasing the fuser...
I applied some grease to the long silver rods ends that sits under the drum/developer unit...
I also greased the springs on the ends of the silver roller....
I now have a noise... it does not occur as often... but its a high pitched... noise...
my next step is to take the machine to the office and disassemble and grease the gearbox...
and also try to disassemble and grease the fuser thoroughly... even the ends of the fuser...
but I checked the service bulletins and found
fuser noise section bulletin 2LV-0082 (G103)
power fan noise bulletin 2LV-0063 (F140)
folded corners noise bulletin E126-2LV-0040
drum noise 2LV-0061 (F103)
what I am checking is...
Is there anyone who has dealt with this issue before... ???
no image problems... no jams... just a high pitched sqeeky noise that sounds like its coming from the fuser
and if so... how do you fix this...???
am I on the right track???
is this overkill what I intend to do???
Just trying to be efficient...
thanks for any help you guys offer...
