installation of taskalfa 6002i
  • kyogenius
    • Jul 2012
    • 136
    [CQ] installation of taskalfa 6002i
    Hi just received this new machine... Did unlocked the scanner and fitted adf,toner cartridge and switched on machine. Is there any setting or simulation that you need to run to initialize the dev unit because after it does it on its own ,I am getting blank copies.Anything special about initial setup on these new models? Any suggestion is most welcome. After checking the dev unit seems to be not turning at all.
    failure is not an option !
  • Geo
    • 662
    Re: installation of taskalfa 6002i
    For setup follow steps in service manual. As for blank copies reinsert and lock D.V. unit .
      • 29303
      enter service mode run think its u130 press start key
      • JR2ALTA
        • Feb 2010
        • 2027
        Happens to everyone. It's the grey push button
        • Luther
          • May 2006
          • 682
          go to sim 952 and follow the setup procedure, it has all the adjustments in the correct order for setup
          • Up to date Tech
            • Jan 2018
            • 31
            Im with you another tech from our company went crazy until he called me and this helped
            • Practic
              • Oct 2014
              • 56
              Agree with Luther. You have to READ CAREFULLY INSTALLATION GUIDE and FOLLOW SEQUENCES AND PROCEDURES. Once - you've done that - there will be no headaches. I have had problems with previous machines, when guys started to use machine just from the box after assemble it (but that was color TASKalfa 3050ci) and they damaged 4 dev units there - without any chance to recover it by Kyocera warranty. And yeah, - if you install this machine just by yourself without involving kyocera tech - you may loose warranty. Need to check that and ask questions to your reseller.
              And if you OK with that and self-confident, you will need latest revision of service manual and probably latest firmware.
              You can do it, just need some time for it. Good luck!
              Sent from Ericsson DBH 1001.
              • sparkycivic
                • Apr 2017
                • 348
                the new developers have the stupid grey button on the front to engage the roller toward the drum. they can pop out during machine transport, and we have also had a handful of damaged developers where the button will not stay engaged, or only stays partially engaged due to breakage of the plastic tab. It's happening on some of the new color machines as well.
                • justanotherhack
                  • Apr 2015
                  • 74
                  Stupid grey push buttons pop out by themselves on smaller color units generating service calls.
                  • Master_hamid
                    • Feb 2025
                    • 9
                    Taskalfa Printer and Scanner Installation Procedure
