SCS 4550ci Cannot perform Toner curve adjustment message
  • Doug James
    • Jan 2012
    • 935
    [Misc] SCS 4550ci Cannot perform Toner curve adjustment message
    I am getting this machine ready to sell. It runs great with no problems. I cannot calibrate or do toner curve without getting the message Cannott perform after the copier tries to read the printed chart. I have cleaned the optics and the copies look fine just can't do the calibrations.. Any help would be very appreciated as I want to sell a good product....
    • 22920
    Re: SCS 4550ci Cannot perform Toner curve adjustment message
    Are you laying the charts on the glass in the wrong position on the glass or rotated? The arrow goes in the back left corner, chart face down. I lay 20 sheets of white paper behind the chart to hold it down, and get a better read.
    Are any of the lighter squares incomplete or missing. It 's usually 1 specific color. That will cause the calibration to fail also.
    I could tell you more if you printed off the 11% ANSI A Color test charts and scanned them into this thread.
    • tmaged
      Owner/Service Manager
      • Oct 2008
      • 1857
      There is something it's not seeing that it needs when it's trying to scan. Check your 089 & what Blackcat said.
      Hope that helps !
      -Tony
      www.dtios.com
      Become a fan on Facebook
      • darry1322
        • Oct 2010
        • 817
        Make sure your print alignment and color alignment are good. I had one machine that was off on lead edge timing and wouldn't scan the charts correctly.
        • yakyitz
          • 241
          you might also try and do maintenance mode 425 with kyoceras calibration charts
          • Scott
            • 189
            All posts are correct, something isn't right
            • Ropariva
              • 628
              • Doug James
                • Jan 2012
                • 935
                I ended up changing the black drum and it started working !! I haven't figured out how to get a color ansii chart yet. Sure do appreciate all the responses !!! Thanks You !!
                  • 22920
                  See attached:
