C6526 with error C7404
  • axyun
    • Aug 2007
    • 1323
    I removed drum + dv unit and cleaned out spillage etc. Did not notice anything obvious with y dv unit. Reinstalled but c7404 still appears.
    Any help is appreciated. Frank
  • JR2ALTA
    • Feb 2010
    • 2028
    Re: C6526 with error C7404
    I would say the issue is definitely the chip of the unit NOT the machine. I had a bad drum chip out of the box on that model. You'll have to replace the unit.
    • axyun
      • Aug 2007
      • 1323
      Thanks JR. Should I assume you are referring to dv unit as dv and drum units are separate on this machine and the C7404
      I believe is referring to y dv unit. Have little experience on this machine but what I have had has been a nightmare. I will post results if there are any
      • JR2ALTA
        • Feb 2010
        • 2028
        They are separate but they both have chips and are both known to become unreadable.
        I see how my example could cause confusion. I just wanted to reinforce that the chip design can be flaky.
