M3040DN Keeps saying adding toner
  • copier tech
    • 8093
    [Electrical] M3040DN Keeps saying adding toner
    Hi all,
    I went to this one today, the fault was large white voids, the dv unit was empty I can see the blank area of no toner on the roller the machine is not asking for a toner.
    I fitted a new toner the machine started to add toner but after 5 mins still asks for toner, powered off/on machine starts adding again then goes into a loop & asks for toner again!? Any ideas!?
  • Sayens
    • Mar 2013
    • 17
    Re: M3040DN Keeps saying adding toner
    Check the toner opening, had a few that it left a film over it, and also open and close the rear fuser door.
    • Kyo fan
      • Dec 2013
      • 368
      Replace the developer clutch.
      • RobertOB
        • Dec 2018
        • 26
        Check for a Blockage in the Feed assembly (Hopper) as well. We had a similar issue in our shop a couple of months back, and the hopper was blocked and had to be manually cleaned out.
        • taskalfaman
          • Nov 2009
          • 137
          Two questions
          -which toner you inserted
          - which drum is inside the machine.
          please take a pciture, most likely one of those is wrong.
          • copier tech
            • 8093
            Originally posted by taskalfaman
            Two questions
            TK-3150 Toner & DK-3100 drum.
            I can see the toner botter is not turning but the drive gear is!?
            • taskalfaman
              • Nov 2009
              • 137
              drum is wrong type
              must be DK-3150.
              have fun
              • copier tech
                • 8093
                drum is wrong type
                must be DK-3150.
                have fun
                Is that right!?
                Kyocera DK-3100, Drum Unit, FS-2100, M3040, M3540- Original
                • copier tech
                  • 8093
                  [ATTACH=CONFIG]41397[/ATTACH]
                  I took the side panel off & could see this clutch driving.
                  • copier tech
                    • 8093
                    drum is wrong type
                    must be DK-3150.
                    have fun
                    Thanks, I think this is where i've gone wrong, previous engineer ordered the wrong drum unit.
                    Correct dev is DV-3100 but drum should be DK-3150 where the logic in that!?
                    However can you explain in future how I know what drum to order, my country voltage is 240v (UK)
                    • taskalfaman
                      • Nov 2009
                      • 137
                      nope
                      DK-3100 => 2100 series
                      DK-3130 => 4X00 series + M3550/60 series
                      DK-3150 => m3X40 series
                      european market.
                      have fun
                      • copier tech
                        • 8093
                        nope
                        european market.
                        have fun
                        Thanks for your help machine up & running now & a lesson learnt!
                        M3040iDN & M3040DN use different drum units!
