TaskAlfa 3252ci - Replace K Toner Message
  • Konicatech
    • Feb 2016
    • 131
  • Santander
    • May 2009
    • 768
    Re: TaskAlfa 3252ci - Replace K Toner Message
    The toner sensor is located in the DV unit. You could use Sim131 and set the toner control voltage manually as a temporary fix, but from your description you will need to replace the DV unit.
    • Geo
      • 662
      Silly question...Are all the components rotating and how many times did you cycle the copier ? Depending on circumstances you may have to cycle it several times or use sim132 to fully restore the toner level .
      • George J
        • 107
        I had a couple of machines where the toner pump was no longer passed black toner, but that generates a fault code. It's a bit of work to reach, but a possibility.
        • taskalfaman
          • Nov 2009
          • 137
          the solution is most likely to change the toner hopper.
          have fun.
