Kyocera 4052ci manual toner door release
  • kuby
    • Oct 2007
    • 1379
    Is there a way to manually open the toner doors to replace the toner on a Kyocera 4052ci?
  • kuby
    • Oct 2007
    • 1379
    Re: Kyocera 4052ci manual toner door release
    Found it. Never mind.
    • gunnerman
      Would you mind sharing where this option is or how you did it?
      I can't find out how for the life of me.
      The user manual states on page 8-75 that the "Open toner cover" option is available under [System Menu/Counter] key > [Adjustment/Maintenance] but the Open toner cover option is nowhere to be found.
      Thanks!
      • kuby
        • Oct 2007
        • 1379
        Found it in the Service Manual. U159 Toner container function setting. Select the Container lock and you have three options. I had a low toner that I wanted to replaced before I delivered the copier so I chose the Low setting. That made the toner door open on the Yellow and then I replaced the toner and then reset the option back as it was. (Empty).
        • Billy Bob
          USMC
          • May 2011
          • 51
          you can also use a magnet, (from door latch) rub it on toner door till you hear a click then it will open to unlock toner
          • JR2ALTA
            • Feb 2010
            • 2028
            I was taught the magnet trick at school but now it never works. Is there another step I'm not remembering? I hear the click.. Then what?
            • Billy Bob
              USMC
              • May 2011
              • 51
              after the click you have to pull open that little door , then move the lever on the top to disengage the toner
              • progoffice
                • Nov 2008
                • 334
                You can also do it from the Command Center RX web interface. To the right of the toner level display is a button that says "Unlock".
                • itchyfinger@att.net
                  • Oct 2017
                  • 77
                  [ATTACH=CONFIG]41720[/ATTACH]
                  you can also pull the cover off next to the black toner to the right and move the selonid by hand
                  • sparkycivic
                    • Apr 2017
                    • 348
                    You just need to use a stronger magnet.
                    I keep some choice 3.5" HDD actuator magnets around that will yank the secret cover right off, when approached at the upper-half... super handy when unboxing machines.
                    My magnetic screw holder pan barely opens the door
                    • GeneOR95
                      • Feb 2018
                      • 161
                      In U159 select Container Unlock Display Setting to display the toner lock release operation.
                      then select On Display the lock release selection in the System Menu --> [Adjustment/Maintenance] screen
                      It will now appear as the last option in the System Menu --> [Adjustment/Maintenance] screen.
                      • oldtech1
                        • Mar 2008
                        • 35
                        i use the magnet for the front cover latch
                        • kuby
                          • Oct 2007
                          • 1379
                          Never had luck with the magnet.
