FS-4200DN Command Center RX reset password
  • _bolek_
    • Jun 2011
    • 7
    Hello,
    so i have 4 Kyocera FS-4200DN and i don't have passoword for them.
    if remember correct its first generation that have Commend Center RX
    Of course i tried many things (searched if there is keypad combination to reset default)
    I have tried Prescribe but i don't think that will work because is for older devices like FS-4020 :/
    When i try form KM-Net View i got error "not authorized" etc. from USB Drive its accepted but notin more :/
    In SM there is FRPO but no command to reset/change password (init could help but without actual default settings i don't want to do this).
    Any suggestion except Engine reset?
    PS: this devices don't have jumpers like older one so don't suggest to use jumper to reset password.
    • 22917
    Re: FS-4200DN Command Center RX reset password
    Just the Engine Reset. =^..^=
    • GeneOR95
      • Feb 2018
      • 161
      To use Netviewer,
      First access the device in KMNetViewer by using the "Administrator" password (usually the numeric password.)
      To do this, when you first "discover" the device in KMNetViewer use the "Administrator" password in the box for "Administrator Command Center Password" in the Communications dialogue and Admin/Admin for the Login dialogue.
      See
      ResetAdminPW.pdf
      Otherwise -
      Send this Prescribe command to the printer.
      !R! EGRE; EXIT; - initialize the engine board, resets all passwords.
      • _bolek_
        • Jun 2011
        • 7
        Ok i found a way to reset without resetting engine board.
        its that same way that one person post on forum but i wasn't sure that this will work with newer machine but its worked.
        its form this post FS-4020DN old firmware and Command Center password
        This is command reset password form DeviceAdmin not user Admin. But if you have DeviceAdmin then you can reset any password
        @GeneOR95
        i know how to use KM-Net and other Kyocera tools (not only public available - i was for over 15 yest certificated Kyocera Dealer) but this was not a answer to my question. but thx.
        • Don N.
          • Nov 2011
          • 409
          I know this is somewhat an old post but just in case someone is looking for how to reset Command Center RX password on the 4200 / 2100 series printers it can be done from the printers' interface.
          From the printer menu, go to User / Job account - OK
          Log on P/W for Device
          Note - Here is the "device log on" from service manual.
          FS 2100 (4000)
          FS 4100 (4500)
          FS 4200 (5000)
          FS 4300 (6000)
          Go to User Login Set - OK
          Local User List - OK
          Admin - OK
          Arrow to Login User Name - Edit
          (This is where you reset User Name default - Admin)
          Arrow over to Login P/W - Edit
          (This is where you reset P/W default -Admin)
          After resetting P/W you will be prompted for a 2nd time to confirm.
          Back out and turn printer off / on and you should be able now to log in the Command Center RX with your new U/N &n P/W.
          Hope this helps someone.
          • claudiusabau
            Yes it works! Thank you very much for sharing the reset procedure.
            Claudiu
