Error code 0610 cs-5035
  • NEEDHSD
    • Apr 2025
    COPYSTAR CS-5035.
    Displays error code CO 0610 on startup.
    I replaced both Ram memory.
    Has same error code with new rams.
    Could not find error codes in my manual.
    Thank you.
  • zaza
    MECANOGRAPHE
    • Mar 2008
    • 1095
    try this....
    Originally posted by NEEDHSD
    COPYSTAR CS-5035.
    Thank you.
    hi dear technician friend NEEDHSD...means code c 0610
    - BITMAP PROBLEM: there is a probleme with the data or adress bus of the bitmap DRAM
    - CAUSES: defective main PCB
    - SOLUTION : Replace the main PCB and check for correct opertion.
    try this ..and good chance my friend NEEDHSD.
    BEST TECHNICIAN . NICE PEOPLE .
    • NEEDHSD
      Will the cs 5035 pcd be the same part as for the km-5035?
      • zaza
        MECANOGRAPHE
        • Mar 2008
        • 1095
        AHA
        hello NEEDHSD ...yes it have same code error .
        • vikingmita
          • Nov 2008
          • 163
          c0610 can show up for several reasons. as always: new fw first, then check connectors and last: change main pcb.
          • NEEDHSD
            new fw first
            Thank you.
            Please tell me what does fw stand for?
            • termacadon
              IT goofball
              • Oct 2008
              • 66
              FirmWare
              • NEEDHSD
                Thanks!
                Thanks!
