CF000
  • mwangi
    • Aug 2019
    • 2
    [Error Code] CF000
    Thank you copytech for creating this forum. My Kyocerra ECOSYS M2035dn is displaying the above error oftenly. What could be the problem and how do i fix it?
  • GeneOR95
    • Feb 2018
    • 161
    Re: CF000
    There is no CF000 code listed anywhere in the service manual or on Astea for this model. The closest match is F000. A printing issue causing this code was corrected with firmware in 2016 so this is not highly likely the problem.
    The next cause for an F000 is Control PWB - Operation panel PWB communication error.
    1) Harness (check all connectors),
    2) bad op panel
    3) bad control PWB.
    And yes, update firmware to latest.
    • Geo
      • 662
      Re: CF000
      You didn't tell us if the code happened during printing , copying or both... But I would guess it's during printing, so make sure they are using the newest drivers and delete all old driver versions . Also , as mentioned, newest firmware is a must and even if it has the newest, reflash with the full version.
      • Reed
        • Feb 2011
        • 243
        Re: CF000
        With a weird error like that I assume you disconnected the Network cable and or / usb and power cycled the machine? That is an easy way to see if you have a corrupt print job causing the error. If the machine comes to ready, watch what happens when you plug in the network cable
          • 22916
          Re: CF000
          yes, CF000 = F000. Same code. I haven't seen it on these newer models, but on FalconIII and Stratos it was caused by a communication error between the op panel and controller PWB. The actual causes in the past have been:
          Controller EEPROM
          Op Panel EEPROM
          Controller Board
          Op Panel PWB
          Harnesses
          Firmware
          Print Data Errors
          ... in that order. I usually address multiple concerns like this on a cost basis. What's the cheapest?:
          Firmware
          then Print Data Errors (connect the MFP via crossover to your laptop then see if the errors occur).
          Harness
          EEPROM (+ firmware, of course)
          Op Panel (+ firmware, of course)
          Controller PWB (+ firmware, or course).
          There's nothing really new to this post, but it's organized in a way that may make sense to you. =^..^=
          • mwangi
            • Aug 2019
            • 2
            Re: CF000
            Thank you for your concern,
            The above error code appears during starting up of the printer such that it fails to display the icons on the screen menu.
