Kyocera Ecosys M5526cdw
  • jrob416
    • May 2011
    • 112
    [CQ] Kyocera Ecosys M5526cdw
    I have a Kyocera Ecosys M5526cdw that is printing docs with horizontal lines. Black line on B/W images, color line on color image. Cleaned the K charge roller and the transfer roller on rear door. Fuser looks new. Machine has 27,300 pages run through it. Nothing has made a difference.20191001104040202.pdf
  • FriendlyTech
    • Jan 2018
    • 30
    Re: Kyocera Ecosys M5526cdw
    I'd look @ repetitive defects gauge in service manual and see what it matches up with. I would guess drums just from what i'm seeing.
    • craigster
      • Apr 2016
      • 201
      I would be looking at the primary transfer unit and firmware upgrade.
      There is a bulletin for a new style transfer assy and firmware for lines
      • jrob416
        • May 2011
        • 112
        [QUOTE=FriendlyTech;827199]I'd look @ repetitive defects gauge in service manual and see what it matches up with. I would guess drums just from what i'm seeing.[
        Went back this morning to try something different and found the MFC was printing beautifully. No lines at all. Only thing I could think of was a power fluctuation of unknown origin. Thanks for the response.
        • Ropariva
          • 628
          [QUOTE=jrob416;827284]
          Likely machine has sat for a while and there was moisture between belt and drums. Just needed some time and some copies.
          • spree
            • Jun 2012
            • 211
            I have problem with copying (black or color): very faded picture. Before I will change CIS (scanner), it is possible to calibrate scanner? In user manual nothing... Printing is good quality /printing the configuration page from machine is good quality, too/.
            I have no access to service manual. And at the Kyocera driver website: no firmware available for download.
              • 22801
              if you are an end user you will not see the firmware or service manuals.
              for a small contribution to CTN you can get what you need: https://www.copytechnet.com/forums/v....php?do=donate
