KFS Triple Tier Color
  • aktech
    • Apr 2019
    • 19
    How come on some of the machines we have on KFS can see the triple tier copy counts and on others it doesn't show up ? Is it way we set up KFS on machine or settings some where in the KFS site ? Appreciate any help, thanks.
  • CWP
    • Jun 2013
    • 168
    Re: KFS Triple Tier Color
    Are you absolutely certain that 3-tier color has been turned on at the machine? If it is not enabled at the machine you won't see it on KFS.
    • rigthejig
      • Jan 2015
      • 14
      I've had that problem, upgrading the firmware worked for me.
      • lanierboy
        • 149
        Three tier billing has to be enabled on the device, as standard this is off.
        • Xer0615
          • Jan 2019
          • 48
          There are some devices, older desktop printer-only models, where a script has to be written for this to be enabled as well.
          Had someone in our billing dept ask me to go out and find out why it wasn't reporting it's color tiers, got there and there were no tiers on the status page nor any simple way to enable it. Calling the kyo reps they informed me you basically had to program the function into the device-- Something I never pursued.
          • rigthejig
            • Jan 2015
            • 14
            On the colour printers, not showing three tier billing , you have to enable three tier billing by sending three files to it by using ftp.
            • mincopier
              • Dec 2015
              • 290
              To enable/disable 3 Tier counters:
              service mode
              mode U332
              Set Mode to 1 to enable or 0 to disable
              Leave other settings as is for it to count properly. According to the bulletin, even when set to off these counters are still counting, just not shown on the status page.
              • Bobz1993
                The others are correct. You will need to enable color tiers to see the counters.
                For any devices with a maintenance mode this can be done in U332 by changing the mode to +1. You can even change this setting in KFS under Tasks -> Maintenance Mode. See attached.
                Desktop printers have to be done with prescribe on-site or if you're feeling really ambitious, by remoting in and sending the scripts from the user's PC.
                • aktech
                  • Apr 2019
                  • 19
                  I guess should have explained bit better. The machines were having problems with do have three tier turned on, it shows up on the status sheet. It's just not showing in KFS in all cases. Are there other settings on the machine that need to be enabled other than just turning on three tier for it to report the three tier readings ?
