Kyocera TA 4053 ci Has Blue Screen
  • Dilip
    • Jul 2019
    • 2
    Kyocera TA 4053 ci no display only fan working and has Blue Screen
    when power switch is turned on a blue screen comes on the display screen and fan working..nothing else.
    Not even scanner.
    But Did update firmware.
    screen is working on another machine. so screen is good.
    only two month old machine.
    any Help will be appreciated.
    Thank you
  • kuby
    • Oct 2007
    • 1370
    Re: Kyocera TA 4053 ci Has Blue Screen
    Had a similar issue with a 406ci and ending up replacing the Main PWB.
    • Tonerkiller
      • Oct 2012
      • 665
      On previous models the solution was always main board or HD.
      • Dilip
        • Jul 2019
        • 2
        Not even scanner.
        Thank you
        Thank you everyone for help,
        Finally i found Main high voltage PWB (High Model) 🤣 is problem.
        so basically connector YC1 and YC2 bring down to the blue screen.
        hope this will help all.
