Triumph adler 2506ci
  • dizis
    • Dec 2019
    • 3
    hello, the cyan changed to a new drum.where there might be a problem.
    TA 2506ci (kyocera 2552ci).
    thank you
  • GIUBOSS
    • 1382
    Re: Triumph adler 2506ci
    problem suddenly appeared? Can you check the development units / drum?
      • 22920
      When you installed the new drum did you press that little square gray button on the front of the cyan developing unit? That button swivels the developing roller close to the drum. When not pressed, you get no developing. =^..^=
      • Luther
        • May 2006
        • 682
        I just went thru this, it turned out to be the cyan laser....had no error code other then color registration codes only listed on the event log
        • dizis
          • Dec 2019
          • 3
          • dizis
            • Dec 2019
            • 3
              • 22920
              You certainly don't have to do what I suggest. Please feel free to think of something else. =^..^=
              • Copierstud
                • Nov 2019
                • 38
                Im pretty sure blackcat has this one nailed on the head.
                • nathicana
                  • Aug 2008
                  • 327
                  If it is a 2552ci type machine I don't think the square gray button is there, those are used on the higher speed machines
                  • lanierboy
                    • 149
                    thank you
                    check or replace the high voltage board for the drum units
                    • KYO_OEM
                      • Aug 2011
                      • 684
                      check coupling for drum drive.
                      Have had several cases with no more drum drive after mounting from new drum.
                      • wragsdale
                        • Jul 2014
                        • 188
                        I could be wrong, but I'm pretty sure it's a 6052ci.
                        edit: Oh, you're right. My bad!
