Utax 2500ci kyocera taskalfa 2251ci c7911
  • avio2
    • Jul 2010
    • 150
    hello i have strong problem here
    in advance i have changed main drive (DR895A) for problem noise and very long stabilization - reassembly and worrk correct but minimun noise to DR895C and i have changed this : AFTER C7911
    i have changed in sequence : DV 8325K - PWB DRUM DLP CONNECT- PWB ENGINE CONNECT and the machine not work!!!!!!!!!!!!
    i have tested whit simulation - motor-sensor and (clutch for rotate dv k)and work correctly!!!!!
    it seems to me that the dv tries to fit in but for life i can't understand why and i haven't touched them
    anyone have idea for this?
    thank's in advance
  • Scottb
    • Apr 2013
    • 303
    Re: Utax 2500ci kyocera taskalfa 2251ci c7911
    have you check for bent pins where the DV connector plugs into
    • avio2
      • Jul 2010
      • 150
      i have check this and moved the eprom dv card to the rear but not work!!!!!!! ever c7911
      • Scottb
        • Apr 2013
        • 303
        In that case maybe when you were replacing the drive unit the DV wire got unplugged in the back of the machine.
        If it wasn't giving the C7911 before the drive unit replacement, and it came up immediately after power on. it was something that you did in the back of the machine...ie...leaving something unplugged or possibly unknowingly severing a wire.
        • KYO_OEM
          • Aug 2011
          • 684
          Maybe NO DV or DK would recognized.
          What do you see at U117 + U984? (diff. and real SNs or not)
          • avio2
            • Jul 2010
            • 150
            • avio2
              • Jul 2010
              • 150
              yes sn dv k equal sn dv y
              • KYO_OEM
                • Aug 2011
                • 684
                look for attachment
                • KYO_OEM
                  • Aug 2011
                  • 684
                  by the way,
                  why you didn`t ask Enrico/ Milano if you fight against UTAX 2500?
                  • avio2
                    • Jul 2010
                    • 150
                    look for attachment
                    thank i have check this bt and move and fixed pwb more rear to sk dlp
                    • KYO_OEM
                      • Aug 2011
                      • 684
                      if still present, remove step by step each Dv and DK , TR and Fuser until you see correct serialnumbers.
                      Maybe 1 DV or DK breaks the serial communication line.
                      Maybe yellow or bk Dv is faulty
                      i hate this error, have had 2 cases like this, after mounting from MK kit suddenly C791x.
                      Also after mounting back from original parts...
                      Finally we used these systems for trash.
                      • avio2
                        • Jul 2010
                        • 150
                        • KYO_OEM
                          • Aug 2011
                          • 684
                          • avio2
                            • Jul 2010
                            • 150
                            • avio2
                              • Jul 2010
                              • 150
                              sn correct all part dv c-m-y dr c-m-y-k tr and fuser
                              only sn k is bad
                              you have a BIG HAMMER?
