Ecosys P7240cdn -Three Tier setup
  • kuby
    • Oct 2007
    • 1370
    Have tried to set the Color three tier with the Prescribe commands: I ran each line as a separate Print command.
    !R! KCFG "TCCM",1;exit;
    !R! KCFG "STCT",1,50;EXIT;
    !R! KCFG "STCT",2,100;exit;
    But still does not show up.
  • CWP
    • Jun 2013
    • 168
    Re: Ecosys P7240cdn -Three Tier setup
    Kuby,
    I think the bulletin may be slightly incorrect; try the following commands with single quote '. This was written as one command to turn tiered on, set values, and print status pages.
    !R! KCFG'TCCM',1;
    KCFG'STCT',1,20;
    KCFG'STCT',2,50;
    stat;
    stat1;
    EXIT;
    • kuby
      • Oct 2007
      • 1370
      Thanks, fixed it. The stupid Windows 10 drivers were messing it up. Have to go it and make sure that Windows 10 does not automatically install WSD drivers for Kyocera even though you install it VIA Tcp/Ip.
      • taskalfaman
        • Nov 2009
        • 137
        you just putted different levels as asked
        asked
        O-2
        2-5
        +5
        suggested
        0-5
        5-10
        +10
        this van have a huge inpact if the customer is charged with toner coverage.
