Replace toner K message won't clear, P6235cdn
  • Mr2crazed
    • Jun 2014
    • 35
    [Misc] Replace toner K message won't clear, P6235cdn
    I'm working on a ECOSYS P6235cdn with an error message of "Replace toner k" that will not clear after replacing OEM toner. Tried another toner with same results. Also tried a known good black developer unit and inspected ID connection at the machine for bent pins. The printer has always had OEM toner installed.
    Any ideas??
    Thanks.
  • Tonerkiller
    • Oct 2012
    • 665
    Re: Replace toner K message won't clear, P6235cdn
    I think I seen a bulletin about this. Open and close the back door with the machine on.
    • tcook
      • Apr 2013
      • 37
      Also check the transfer belt. Toner goes through an auger assembly in the belt before reaching the developer unit.
      • nathicana
        • Aug 2008
        • 327
        The board that detects the toner cartridge may have a problem.
        302TV94060 PARTS PWB ASSY CONTAINER CONN
        Item 6 in Fig 13 electrical components 1
