Kyocera 7002i thick solid black line
  • Necrocannibal
    • May 2008
    • 200
    This machine has been doing this off and on and will stop doing it for months and then start doing it again. It is very sporadic and usually only does it once or twice a day or usually only a couple of times a week. Kind of looks like high voltage shorting out for a second and we put a new kit in it not too long ago, it did it before and after the kit. I have attached an example of it and paper is traveling in direction of the arrow I put on the sheet, we told the customer it is hard to diagnose if it only does it a few times a week.
    • 22801
    Re: Kyocera 7002i thick solid black line
    so a halfstop test... is the mark on the drum?
    if no do another and let it get to the fuser.. is it there.
    diagnose from that point.
    Before doing this clean the machine completely.. also check transfer roller
    • Necrocannibal
      • May 2008
      • 200
      Problem with that is it only does it once a day, maybe, so we have no idea when it's good to do it. The machine has been completely cleaned when we put a brand new maintenance kit in it and it did it before and after the kit was installed. The machine night make 5 of these a week at random times of the day.
      Sent from my SM-G955U using Tapatalk
      • jqueen
        • Jul 2015
        • 55
        Does it do it during the copying process or printing process or both? This looks like a copy...and if it is, is it on the glass or through the doc feed???
          • 2621
          Is it the latest firmware?
          TASKalfa_7002i_...2020-02-10)
          • toddanderson
            • Dec 2005
            • 231
            replace the transfer belt, The kyocera rep that Handels Wisconsin and Illinois gave a webinar on trouble shooting with a sample like that
            and it was the transfer belt.
            • tsbservice
              Field tech
              • 7899
              Tough problem at this rate. I would think also high voltage sparked intermittently.
              P.S
              I like also your post count vs rep power and good quality scan sample
              • Santander
                • May 2009
                • 768
                If you look at the sample you provided, the black stripe has a margin, it does not go to the edge of the page. That tells me this is a scan issue and not a print engine problem. If it was a print engine issue it would extend to the edge of the page, since you have the margin it is caused by a scan issue. Thoroughly clean the optics. It is probably a "dust bunny" that gets in the way of the optics path on occasion. Hope this helps.
                  • 22801
                  good catch!
                  • Necrocannibal
                    • May 2008
                    • 200
                    What I scanned was a print from a PC not a copy, if it was dirt or dust in the optics the "line" would also follow the paper path not be perpendicular with it. The black "line" will appear at random places on the page but it's always about the same size.
                      • 22916
                      I've seen this resolved by the developing unit. =^..^=
                      • Brianneoe
                        • May 2015
                        • 318
                        I fixed this problem yesterday. It was kicking my butt for awhile until it became more frequent. Its the ground bearing for the drum shaft. I was able to confirm the problem before I cleaned it and then after. Pull out the shaft and pull off the drum motor. Clean the bearing and the shaft where the bearing sits. If you have a new bearing use it. Once I cleaned the bearing the continuity was firm. At first a though the problem was with ground to neutral high voltage. I was getting from my Sure Tester anywhere between 1.5 to 10 volts. It would start first thing in the morning and then go away after the first 50 copies with about 5 copies having the black bands. Happen every morning and then go away.
                        BTW- I was getting no continuity off the bearing before I cleaned the bearing and shaft. As the bearing moves it makes for a good ground hence the reason why it only happens on start up first thing in the morning. Machine has 3M plus on it.
                        Good luck
                        • Brianneoe
                          • May 2015
                          • 318
                          Sorry to report that the Drum ground did not resolve the issue. Went back to the account and had the same black stripes as shown on your sample. Needless to say I was Bummed out. The Drum ground continuity is good after I cleaned the bearing and shaft but to be on the safe side I replaced it anyway. The Drum and DV units were also replaced but did not help with this issue. Im going to replace the connector for the main charge plus the HV board. Need to remove the Drum shaft again to remove the Main charge connector. At this rate I can do it with my eyes close. Will update you if that works
                          • toddanderson
                            • Dec 2005
                            • 231
                            Replace the transfer belt
                            • KYO_OEM
                              • Aug 2011
                              • 684
                              i agree with toddanderson.
                              At first change belt and check grounding from it.
                              New belt solved 2 cases, on other case only exchange from complete conveying unit fixed it.
