Kyocera M3655idn welcome screen
  • keith huntoon
    • Jul 2020
    • 5
    I have a Kyocera M3655idn.
    Screen stuck on welcome.
    Machine has USB ports blocked(Bank).
    Can not upgrade firmware thru USB port.
    Can not get into Simulation to clear memory and hard drive.
    No network connection.
    Thanks in advance.
  • bmwmick
    • Jul 2019
    • 27
    Re: Kyocera M3655idn welcome screen
    Does anything turn at all when you first turn the machine on
    As I have the power supply cause this fault
    Not on this model though
    • JR2ALTA
      • Feb 2010
      • 2027
      Thanks in advance.
      The bank's IT needs to unlock the USB port for you. Gotta try fw before ordering parts.
      • keith huntoon
        • Jul 2020
        • 5
        Hello
        Yes fans and gears turning
        • keith huntoon
          • Jul 2020
          • 5
          Hello
          The machine does not have a network conection
          • copier tech
            • 8093
            Thanks in advance.
            You need to update the firmware to resolve this issue.
            However if the USB ports are blocked/disabled? you can't unlock them with the machine not coming to ready.
            • copiertec
              • Jan 2016
              • 2184
              You have to start with firmware. Also, just a suggestion, I would have the IT dept either be on site anytime when you are there to service the mfp, or give you the admin code to access the mfp because the extra trips your company needs to make are costing you money.
              • copiertec
                • Jan 2016
                • 2184
                Also, I was thinking if you do have access to the copier, if the admin passcode was not changed you can lower the security level of the mfp or allow usb connectivity though the system settings, then when you are done just re disable/enable those options.
                • GeneOR95
                  • Feb 2018
                  • 161
                  Hello
                  Laptop with crossover cable. Modern Laptops can use regular ethernet cable. Log into command center unblock usb port, upgrade F/W, re-block USB.
                  • copier tech
                    • 8093
                    With the machine stuck on the welcome screen & not coming to ready his options are limited.
                    • CWP
                      • Jun 2013
                      • 168
                      Keith,
                      It would appear that nobody is really looking at the problem as you described it.
                      So if the USB ports are blocked, you would need to unblock them to update firmware, but you CANNOT do this because the machine is stuck in "Welcome".
                      Others are telling you to web into the machine to unblock the USB ports, but if I am correct you stated there is no network connectivity to this machine.
                      At this point, you pretty much have to go with a board failure and it would almost have to be the operation panel or main control board.
                      Maybe you have another machine you could pull the operation panel off of to try.
                      • GeneOR95
                        • Feb 2018
                        • 161
                        And right now his options are to try to access the command center or replace boards. I always try the least expensive option first, especially the free ones. At most you lose ten minutes trying.
                        • keith huntoon
                          • Jul 2020
                          • 5
                          Thanks in advance.
                          We ended up replacing PWB Assy. Controller board.
                          Seems to have solved the problem.
                          Thanks to all who responded.
                          • JR2ALTA
                            • Feb 2010
                            • 2027
                            Originally posted by CWP
                            Keith,
                            You're right. This went right over my head. As one who suggested it, I apologize.
