Error code c6030
  • quitech
    • 82
    Error code c6030
    Hi, please how can I reset error code c6030 for Kyocera taskalfa 2551ci, I try u163 no help.
    Thanks for quick respond please
  • copier tech
    • 8096
    Re: Error code c6030
    Try U906
    • Code: 6030
    • Description:Fuser thermistor 2 (center) break error
      A/D value of the fuser thermistor 2 exceeds 1010 bit continuously for 1 s during warming up.
    • Causes:Defective connector cable or poor contact in the connector. Deformed connector pin. Defective fuser thermistor. Defective PWB.
    • Remedy:Defective connector cable or poor contact in the connector. Reinsert the connector. Also check for continuity within the connector cable. If none, replace the cable. Fuser thermister2 and fuser PWB (YC2) Fuser unit and engine PWB (YC30)
      Deformed connector pin. If the I/F connector pins of the fuser unit and the main unit are deformed owing to foreign matters, such as paper dusts, replace the connectors or the units including the connectors.
      Defective fuser thermistor. Replace the fuser unit.
      Defective PWB. Replace the engine PWB and check for correct operation.
    • Copierstud
      • Nov 2019
      • 38
      Replace the fuser.
