Kyocera Ecosys P6130cdn & Ecosys M6535cidn spots/lines
  • StratManDan
    • Nov 2018
    • 96
    [CQ] Kyocera Ecosys P6130cdn & Ecosys M6535cidn spots/lines
    Hi all,
    I'm curious if anyone has seen a print issue, common with these two models, and seems to effect only the K drum. Rarely, have I seen any of the cyan, magenta, or yellow drums do this, but it does happen.
    I'm almost convinced the issue is due to the K drum's cleaning blade failing to remove all the toner, paper dust, or other garbage floating around within the machine. Why the K drum is effected more than the other drums is a mystery, at this point.
    The foreign matter can be cleaned off the drums surface, with a soft, lint free towel, and a little alcohol, however the issue tends to return, in some cases, in a matter of days. After three or four cleanings, I've simply resorted to replacing the drum altogether. The cleaning blade can be removed and cleaned, as well.
    The biggest mystery is, where is this stuff coming from? Damp toner? Paper dust & humidity?
    I've attached a print sample that shows the issue, to a small degree. In some cases, it's much worse, and can sometimes appear as little, black "raindrops" covering only partial spaces of the print, up to completely covering the whole page.
    Any suggestions, ideas, and recommendations are welcomed!
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1857
    Re: Kyocera Ecosys P6130cdn & Ecosys M6535cidn spots/lines
    Have the same issue. It's never really been resolved from my experience. I beileve it's because it sits close to the fuser. I also think there might be too much wax in the toner causing it.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • StratManDan
      • Nov 2018
      • 96
      That makes perfect sense! Another question I've asked myself, but have yet to come up with an answer, is "Am I somehow depleting the life of the drum by cleaning it with a towel and alcohol? By cleaning the drum in this manner, it seems to be inviting the issue to return only sooner, than actually being a final-fix. It does, on the other hand, makes my productivity numbers look good!lol!
      • StratManDan
        • Nov 2018
        • 96
        That makes perfect sense! Another question I've asked myself, but have yet to come up with an answer, is "Am I somehow depleting the life of the drum by cleaning it with a towel and alcohol? By cleaning the drum in this manner, it seems to be inviting the issue to return only sooner, than actually being a final-fix. It does, on the other hand, makes my productivity numbers look good! lol!
        • ntbann
          • Jan 2012
          • 622
          They released a new K drum for these. They work a little better but will still do it.
          • ntbann
            • Jan 2012
            • 622
            Part # 302NR93180
            • copier tech
              • 8096
              Originally posted by StratManDan
              Hi all,
              This model/engine has always had this issue.
              I do as you have a clean it off with alcohol etc I then swap the K & Y drum around.
              I have a lot of the 266ci models they all do it.
              • StratManDan
                • Nov 2018
                • 96
                I've done that as well. However, I was told, by a tech that's been in the field for a long time, that the printer will serialize each drum according to where it's installed within the machine. For instance, If I remove a K drum, and switch it's position with the yellow drum, it could possibly void it's warranty. Is this a valid claim?
                • ntbann
                  • Jan 2012
                  • 622
                  That's why we put the new drums in. Warranty old. If you scrub them it just shows back up in 2 weeks. And yes drums are serilized. A k drum now has a new part number.
                    • 22920
                    The bulletin says that Kyocera added spacers behind the drum blade to improve drum cleaning. And it is some ingredient of the toner adhering to the drum.
                    I hadn't much considered the proximity of the black drum and the fuser. Perhaps shortening up the sleep timer would help. Also removing any obstructive ozone filters and cleaning the fan ducts. Or moving the whole machine to a better ventilated area.
                    I worked on a console Toshiba this year that kept blowing thermostats at one week intervals. I looked at many of these same things: filters, fan ducts, fans, ... and I found a service mode to extend fan operation time based on internal temperature. That was the golden nugget I got from that call. Maybe Kyocera has a way of keeping the fans running longer.
                    Edit: The fuser cooling squirrel cage fan is called "Exit Fan", and resides above the fuser. I'd image it could benefit from cleaning. I do not see a service sim to run the fans.
                    There is sim U059 which defines which environmental sensor controls the fuser fan. You may get some additional cooling benefit from selecting "0" (uses right rear "Outer Temperature Sensor"), rather than "1" (uses left front "new sensor position", to address paper wrinkling issue).
                    To select faster sleep mode use:
                    U346 > Timer/Sleep Lever > More Energy Save
                    U346 > Auto Sleep > ON
                    Sleep Timer is set in FRPO Parameters N5, values from 1 to 240 (minutes)
                      • 22920
                      So I've got a test case going:
                      It's had two black drums for this same issue within 36K. It's low volume, and in an open area (sports dome). The sleep timer is now changed from 240minutes to 5minutes, with the customers approval. The wake up time is negligible on this machine. Once you wake it, it's maybe 25 seconds until it prints.
                      We shall see ...
                      • copiertec
                        • Jan 2016
                        • 2184
                        We shall see ...
                        I believe the lowering the sleep mode will help reduce the issue. I have noticed on other machines lowering the sleep timer has helped a lot with reducing the prolonged heat damage caused by the fuser, i.e. fuser roller flat spots, premature fuser bearing wear (clicking on the Sharp Frontier series), premature plastic failure, etc.
