Kyocera FS-1035MFP region
  • rapo_tech
    • Feb 2019
    • 114
    Hello
    I have costumer that claims printer does not recognize toner cartridge.
    Gives error: Unknown toner installed. PC
    I am suspecting that the printer and cartridge are not regionally compatible.
    How to check which region is the printer?
    I remember that letters in serial number suggest the region?
    The serial nr. starts with NR (NRxxxxxxxxx)
    • 29290
    Re: Kyocera FS-1035MFP region
    Printer will still work just fine ignore the message
    or return for credit to Kyocera as a defective toner
    • 20gaugeO/U
      • 553
      Is it Generic toner???
      I've seen generic toner that doesn't have the second set of hooks to grab and "lock" the toner in so I think the little RF board on the toner wasn't making good contact and would randomly throw toner messages. Billable customer so what they saved in the generic toner cost them more in the long run with a service call
      • WLIT
        • Jan 2020
        • 40
        You may be able to reset that message by pressing and holding down the stop and OK buttons for a few seconds.
        • rapo_tech
          • Feb 2019
          • 114
          It is our company refilled toner (OEM shell). So the chip is like generic yes...
          But there has not been any problems with those toners.
