TASKalfa 7003i Remote Operation
  • eibyer_ct
    • Feb 2021
    • 2
    Is there a trick to using Remote Operation on the above machine. I followed the manual in enabling Remote Operation but I am failing to connect to it via the browser or VNC.
  • buzz
    • Aug 2013
    • 287
    Re: TASKalfa 7003i Remote Operation
    Do you have KFS?
    • CWP
      • Jun 2013
      • 168
      Make sure you are directing to the correct port i.e. xxx.xxx.xxx.xxx:9062 for VNC to the machine (9062 is default port but it can be changed). Also make sure that VNC is enabled under protocols as well as Management Settings - Remote Operation. You may also have HTTP protocol turned off or something else blocked if you cannot web into machine.
      • tsbservice
        Field tech
        • 7897
        Are you a tech?
        • eibyer_ct
          • Feb 2021
          • 2
          Thanks for the reply guys. I was able to get VNC working after I set the password for remote instead of using Administrator only in the setting.
