Disable MP tray and for printer to use cassette 1 and cassette 2
  • almustafa
    • Apr 2025
    my printer is Kyocera FS-6525MFP
    my issue : when printing printer use by default MP tray I cannot find where is auto paper tray select option in setting ..
    when close MP tray its not printing I must select tray manual in screen
  • rapo_tech
    • Feb 2019
    • 114
    Re: Disable MP tray and for printer to use cassette 1 and cassette 2
    Check that paper size and type on print job and cassette settings are the same.
    If they are different printer asks paper from MP tray.
    • dalewb74
      • Feb 2018
      • 1107
      make the bypass size and type a weird size and type. then whenever you print letter or whatever it should pull from the cassette. assuming the cassette is set to the correct size. i agree with what was said above...
        • 22916
        Make sure that your tray #1 is set to Auto (inch) or Auto (metric), and Plain media type.
        • fishleg
          • Mar 2009
          • 425
          I have a customer who aren't very good at picking paper sizes etc... Anyway to just make it print on A4 if they send A5 etc? Easily without changing 50 pcs printer settings?
            • 29290
            You could setup two printers one for tray 1 and one for tray 2
              • 22801
              did the OP even check the USERS GUIDE for this problem? I.E. Paper Size Mis-Match or Paper Tray Configuration
                • 22916
                Nope. The print driver overrides the printer defaults. =^..^=
                • fishleg
                  • Mar 2009
                  • 425
                  Yeah it's a right pain as they install it themselves so they have a generic driver which loves going to the mp tray.
                  Shame no if you don't have this paper just print on A4 regardless of what's sent.
                    • 29290
                    Install the correct driver to start with that basic stuff
                    You want the KX driver
                    • fishleg
                      • Mar 2009
                      • 425
                      Try telling that to teachers it's a nightmare... They just click add printer good old windows adds a poopy generic driver. All these machines really should have a if you don't have paper size do X i.e. just print centered on the closest possible size. HPs been doing this for years and it works people who don't have the driver ain't exactly gonna all of a sudden be bothered to install the correct one as they can't be bothered. We have a customer with 50 laptops didn't matter how many times you explained look you need to install this driver they all just clicked print and put A4 in the bypass until it broke...
                      I know in a perfect world everyone would install the correct driver but if windows just installs one or the machine let's you send a job from the wrong driver it's always gonna be like this. It would be very easy for Kyocera to build a check into their correct driver so if the machine sees the official driver it works as told but if it's generic or anything else you can select reject job automatically or print on closest size.
