TaskAlfa 3551ci - "black toner empty"
    • 16309
    I was called out to this machine at the end of the day. The customer had just installed a new black toner but the machine still says replace black toner. I tried another new cartridge and got the same results.
    I'm thinking the chip reader isn't reading the chip? This is the first time I've run into this problem.
    Any thoughts?
  • copier tech
    • 8093
    Re: TaskAlfa 3551ci - "black toner empty"
    Any thoughts?
    Have you tried updating the firmware ?
      • 16309
      I believe the machine has the latest firmware installed but I will double check. Have you seen firmware cause this problem?
      • A\ztech
        • Feb 2011
        • 57
        I had the same problem on a 3212i it would not recognize the new toner cartridge even with the latest Firmware. I had to take the drum and Developer units out, cleaned them and reinserted the cartridge, then it recognized it but it didn't show the % so we'll see what happens when they replace it.
          • 16309
          That's odd. I'm gonna try replacing the RFID board. But I seem to remember reading something on here about toner not being added to the DV unit. Can't remember the details, tho.
            • 16309
            EDIT: I think I remember the details on "toner not being added to the DV unit." That was a different problem than mine. I believe the post I'm thinking about was blackcat talking about a DV seal blocking the toner path. Anyway, that was on a 3552ci, I believe and is unrelated to my problem. I THINK.
              • 22916
              Your memory is correct.The AlphardII is not subject to that issue.
              Which toner is installed? TK-8307K or TK-8309K? They look very similar, but the TK-8309K will not be recognized in a Kyocera.
              If the machine is recognizing CMY but not K, I doubt very much that it's the RFID board.
              There is one thing you can check though:
              I did this to myself while changing an engine PWB on a Saturn. The connectors were really difficult to get unplugged ... and during all that tugging, I accidentally unplugged the other end of the harness to the RFID board where it passes through the rear frame union connector. On the Saturn it's behind the engine board, so you can't see it. The symptom was ALL toner cartridges registered "Non-Kyocera Toner Installed" or "Add Toner Black/Cyan/Magenta/Yellow".
              I've also seen defective RFID chips on Saturn toner cartridges.
              Much more common is to find compacted toner in the toner cartridges. What I do in this situation is remove the toner cartridge, open the shutter, then rotate the drive to trickle out some toner. Is it hard to turn? Do you get any toner (or rocks)? Does the inner drive rotate? (I've seen twisted off "D" shafts). Is the whole seal removed? If the drive is intact and the seal removed but the toner is compacted, I'll take the toner cartridge out to the alley behind the building, close the shutter and bang the toner cartridge on the pavement until the toner trickles out smoothly.
              You can also get false "Add Toner" indications if the developing unit gets over-toned, overfilled with toner, or you're losing agitation to the developing unit.
              Whew! That should give you a few things to check. =^..^=
                • 16309
                I believe you covered all the bases, blackcat.
                The carts are TK-8307. C, M, and Y are all reading fine. Only the K is showing empty and needs to be replaced. When I installed a new cartridge it did absolutely nothing. It didn't even try to add toner. It's as if I didn't do a damn thing.
                As far as the connector from the Engine PWB to the RFID board, I haven't touched any boards on this machine but I'll check it out just to be sure.
                As always, you've been a big help.
                • darry1322
                  • Oct 2010
                  • 817
                  Out of left field here but....I've ran across this a couple of times.
                  If the side transport door was opened while the toner message is displayed and then closed but not quite completely closed, the toner message will not clear after replacing the toner.
                  Customer opens the side door and closes it by pushing it on the front top and rear top is still slightly open. Then changes toner.
                  The machine doesn't show a door open message because the toner message hasn't been cleared and the toner message doesn't clear because the side door is "open".
                  Worth checking.
                    • 16309
                    Worth checking.
                    I'll be damned. Thanks for the info. That sounds like something this customer would do. I'll be sure to check it out. Thanks again.
                    • copier tech
                      • 8093
                      Not on this model but its always worth a try, takes 5 mins & costs nothing.
                      • tmaged
                        Owner/Service Manager
                        • Oct 2008
                        • 1855
                        Worth checking.
                        Have had the same issue a couple of times as well.
                        Hope that helps !
                        -Tony
                        www.dtios.com
                        Become a fan on Facebook
                        • tsbservice
                          Field tech
                          • 7899
                          Worth checking.
                          Had it on Konica as well. Very frustrating made me mad for a minute or two.
                            • 22916
                            Worth checking.
                            Maybe similar ... I've had jams that would not clear for this reason. When I got to the right door it cleared ... even though there was no paper. =^..^=
                              • 16309
                              I just got back from the machine and it wasn't the the side door that was open..it was the small door at the top of the copier that wasn't closed good. I'm talking about the door at the switchback unit for the finisher. Like someone else said, the machine wasn't showing the door was open because it was showing black toner was empty and the machine couldn't clear that toner empty condition because the door was open.
                              It really pisses me off at myself for not figuring it out sooner. I'll know better next time.
