Kyocera P2040dw reset password
  • ProfiServ
    • May 2021
    • 4
    Hello, how to reset the login and password for the web interface? Login and password have lost the previous admin. Maybe by prescribe command?
    Sorry for my English. English is not my native language.
  • GeneOR95
    • Feb 2018
    • 161
    Re: Kyocera P2040dw reset password
    Log into the machine's “User Login/Job Accounting” function under the system menu
    with the supervisor account (IE; 4500, 4500 on a TA-4551ci).
    For Printers;
    • From the printer menu, go to User / Job account select OK
    • Log on P/W for Device (See Above)
    • Go to User Login Set select OK
    • Local User List select OK
    • Admin select OK
    • Arrow to Login User Name – Edit
    (This is where you reset User Name default - Admin)
    • Arrow over to Login P/W – Edit
    (This is where you reset P/W default -Admin)
    • After resetting P/W you will be prompted for a 2nd time to confirm.
    • Back out and turn printer off / on and you should be able now to log in the Command
    Center RX with your new U/N &n P/W.
    DO NOT share this info with customers.
    • ProfiServ
      • May 2021
      • 4
      GeneOR95 Thank you so much, I'll try it tomorrow.
      • KYO_OEM
        • Aug 2011
        • 684
        You also can run Data Sanitization unter System/ Network/Data Security.
        But you will loose all data
        • ProfiServ
          • May 2021
          • 4
          GeneOR95 unfortunately I have no "User Login Set" and "Local User List" in my printer's menu map.
          KYO_OEM I have no "System". I have "Security" but under it I only have "I/F Block" and "Security level"
          Any other ideas?
          • KYO_OEM
            • Aug 2011
            • 684
            Do you see on status page above remaining toner amount, the line "Data Sanitization" ?
            If you run this feature, you`ll see date and time stamp after it would executed.
            But i don`t remember the exact location in service menue...
            But it must be a hidden point, you has to type in 2600/2600 before.
            Here a sample from italian market:
            • ProfiServ
              • May 2021
              • 4
              [ATTACH=CONFIG]49202[/ATTACH]
              No, there isn't.
              • KYO_OEM
                • Aug 2011
                • 684
                Prescribe commands won`t work anymore.
                You has to ask KYO for CCRX reset file.
                • kuby
                  • Oct 2007
                  • 1370
                  The default login user name and login password at the factory shipment is set as below.
                  Login User Name: 4000 or 3500
                  Login Password: 4000 or 3500
                  • KYO_OEM
                    • Aug 2011
                    • 684
                    @kuby
                    we are talking about CCRX password
                    Missing Admin/ Admin
                    Without card autentification kit installed, you are not able to create new user with admin rights!
