3552ci C7402 Cyan error
  • buzz
    • Aug 2013
    • 287
    Check out these values in U155 Toner Mix
    29 Thousand!��
    Toner sensor in Developer Bad?
    Looking to replace whole DV Unit
    Any feedback?
    Thanks.
  • KYO_OEM
    • Aug 2011
    • 684
    Re: 3552ci C7402 Cyan error
    See much better information regarding U155
    1. Normally the value are around +/- 14 ( T/C = +/- 2% ).
    2. Typical target values are around 4,500
    3. +100 value stands for when the sensor comes off the unit (The sensor is fixed by welding )
    4. -1,000 value stands for the error when sensor oscillation is abnormal or connector is disconnected
    I think new dv needed
