M5526 and scan to email failure
  • Leebs14
    • Feb 2014
    • 457
    [Misc] M5526 and scan to email failure
    so I have been having a battle with one of these machines trying to get it to scan to email, I have done this a thousand times and am sure the settings are correct but it simply will not work!!!
    loaded the latest firmware today and still the problem persists.
    settings are
    STATIC IP ADDRESS
    GATEWAY AND DNS ALL CHECK OUT
    SMTP Server - mail.smtp2go.com
    SMTP PORT - 587
    SMTP TIME OUT - 180
    AUTHENTICATION - ON
    AUTHENTICATION - OTHER
    LOG IN USER NAME & PASSWORD ARE CORRECT
    SMTP SECURITY - START/TLS
  • ntbann
    • Jan 2012
    • 622
    Re: M5526 and scan to email failure
    Did you try the ip address for mail.smtp2go.com? You may have a dns issue.
    • sparkycivic
      • Apr 2017
      • 348
      what error code is generated upon failure?
      • mojorolla
        The Wolf
        • 2569
        Did you populate the Sender Address under Email Send Settings ?
        What is the error code when it fails. This code will indicate the nature of the error (user /password, name resolution, etc...)
        You can turn off security and use port 2525 to see if you get the same error.
        • Reed
          • Feb 2011
          • 243
          I found another smtp server that I like a little better.
          Sendinblue.com
          You have to register but it allows you 300 emails a day
          Sent from my SM-G955U using Tapatalk
            • 29306
            What's the error code?
            • Leebs14
              • Feb 2014
              • 457
              Sorry i should have put the error code it is 3102
              • Leebs14
                • Feb 2014
                • 457
                I tried another smtp server and got the exact same error - 3102
                • mojorolla
                  The Wolf
                  • 2569
                  Sounds like a DNS issue and it cannot resolve the name. Did you try ip address instead as suggested (47.79.71.155) ?
                  Go into Command Prompt and run ipconfg /all. This will list the default gateway and DNS server address.
                  If the ISP DNS settings fail you can also try Google or OpenDNS
                  • sparkycivic
                    • Apr 2017
                    • 348
                    3102 - error: server response.
                    generic unhelpful stupid error information, thanks Japan.
                    I usually encounter this when the server does not allow access for some reason like two-factor auth needed, or device access granted only explicitly per device. In Gmail, one needs to enable access to "less secure devices" before using a scanner.
                    you might need to wireshark the interface in order to see the server response in plaintext and understand what's really happening.
                    • mojorolla
                      The Wolf
                      • 2569
                      Kyocera also makes a good SMB scanning utility to set up SMB scanning.
                      If email is not required, I prefer this method on these desktop units.
                      • tmaged
                        Owner/Service Manager
                        • Oct 2008
                        • 1857
                        3102 is generally an encryption error.
                        Hope that helps !
                        -Tony
                        www.dtios.com
                        Become a fan on Facebook
                          • 29306
                          User Name and sender name need to the same
