Kyocera P6230CDN "Check the toner container". issue
  • ebulich
    • Jul 2010
    • 46
    Client asked us to look at his machine. It comes up with "Check the toner container". Thinking it was a waste toner bottle issue which they emptied and put back in the machine
    with the neck of the bottle covered in toner. I put in a brand new waste toner bottle. Restarted the machine and stil comes back with "Check the toner bottle"
    Anyone have any ideas.
  • Munter
    Member
    • Jul 2011
    • 18
    This is a message about the toner bottle, not the waste toner bottle. From memory, these are iffy at the best of times, moreso with non OEM toner. I'm guessing the printer shows "Adding toner" and then shows "Check the toner bottle". If so, the printer thinks there is toner in the bottle but the toner density in the dev unit is falling.
    Remove all toners and check that they can actually supply toner, next remove the transfer unit and check that there isn't a blockage in the toner path, then remove the devs and check for blockages and/or broken drive mechanism.
    • KYO_OEM
      • Aug 2011
      • 685
      check toner lock from each cartridge. have had broken gear for toner drive. Gear idle.pdf
      • KYO_OEM
        • Aug 2011
        • 685
        it looks like old Gemini issue, Mebius has diff. container lock, but same problem.
        Switch behind main hvt wouldn`t touched in case of 1 not correct locked cartridge.
        remove main hvt and check small white switch push in lower left corner from frame. B081_2KW_0024_SB.pdf
        • kyotechnz
          • Mar 2019
          • 131
          Is the rear door shut properly?
          • Meisterkoch
            • Nov 2024
            • 1
            Thank you very much. Your description from the pdf solved issue hear.
