Want to delete/format Kyocera HD-6 SSD Board
  • druckerteam
    • Oct 2015
    • 28
    Dear guys.
    We have several Kyocera machines with integrated SSD Boards HD-6.
    We have to delete the SSDs with a erasing software.
    The boards have a special S-ATA port and I cant find a adapter to connect this SSD boards to a computer.
    Here you can find a picture:
    Do anybody have a ideo how can i connect this SSDs to a copmuter?
    Thank you in advance.
    Regards, Paul
  • PrintWhisperer
    • Feb 2018
    • 452
    Re: Want to delete/format Kyocera HD-6 SSD Board
    The 8gb SSD looks like PCIe NVME form factor. Try a PCIe adapter board for NVME SSD. Of course you will brick the machine probably when you format them externally. I believe that SSD has the boot partition. Let us know.
    "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
    • druckerteam
      • Oct 2015
      • 28
      Thanks for the reply.
      I think it is a different form factor.
      Attached is a pic of the SSD.
      I think NVME looks like this? Or I am wrong??
      Regards, Paul
      • GeneOR95
        • Feb 2018
        • 161
        I don't know why you are using a separate application to format the SSD. The machine has a built in function to accomplish this.
        Formatting an SSD
        1. [System Menu/Counter] key > [Common Settings] > [Format SSD]
        2. Format an optional SSD.
        *: When an optional SSD is inserted into the main unit for the first time, it must be formatted before use.
        Formatting will delete all existing data on an SSD.
        *: This setting does not appear if the optional security kit is installed
        • PrintWhisperer
          • Feb 2018
          • 452
          [ATTACH=CONFIG]49719[/ATTACH]
          Regards, Paul
          Not an Normal NVME connection you are correct. The type of SSD still not identified though.
          Seems unlikely to be SATA at 8gb what would be the point.
          • PrintWhisperer
            • Feb 2018
            • 452
            Formatting an SSD
            Mhmm and maybe run MM026 but I wanted to see what happened if he did it his way
            • GeneOR95
              • Feb 2018
              • 161
              Correct. This is an HD-6, an array of chips with a proprietary interface connector. I do not believe there are any adapters available for this connector.
              I may be wrong but I haven't found any.
              • PrintWhisperer
                • Feb 2018
                • 452
                Damn proprietary.....
                Ya I didn't pay close enough attention to the HDD he was referring. Too early for posting here I suppose
                The 8gb SSD is like mSata connector BTW but not this.
                • druckerteam
                  • Oct 2015
                  • 28
                  Okay.
                  Thanks guys.
                  I know that we could format it in the copier, but we need a erasing confirmation with the serial number of the hdd for our customer.
                  This is the point. So if there is no adapter we have to check it with the customer. Thank you very much.
                  Regards, Paul
                  • tmaged
                    Owner/Service Manager
                    • Oct 2008
                    • 1854
                    I would have them pay for a new drive and hand them the old one.
                    Hope that helps !
                    -Tony
                    www.dtios.com
                    Become a fan on Facebook
                    • druckerteam
                      • Oct 2015
                      • 28
                      Yes, you are right. I think we will do like this.
                      Thanks fpr the replys.
                      Regards, Paul
                      • KYO_OEM
                        • Aug 2011
                        • 684
                        You can run "Data Sanitization" by system menue.
                        After "complete" message you can choose print out sanitization report depended to the system.
                        The Data sanitization function will delete everything!
