Hi guys,
I have a Kyocera FS-9530dn that displays error codes 4000 or 5300 every time it starts up or restarts (e.g., Power on shows 4000, then power off and power on again shows 5300. It is in a continuous loop with these two errors). I have checked and replaced the laser unit and the LED discharge bar from the image unit. I also found a BSI that mentioned the front cover switch should be replaced. Naturally, I replaced this switch as well, but without positive results(big BS
). Any ideas? If anyone encountered and resolved this type of defect please leave a comment!
Is a very strange combination of error codes!
Thank you in advance!
Alex
Alex
