I have a 2552ci that jams when duplexing. It gives a J4701. When the machine jams, the paper is partway into the fuser after doing the first side. Doing one sided copy/prints is no problem.
What I have done so far. I updated the firmware. I checked the condition of the actuators in the exit unit and the fuser.
I swapped the exit sensor with the feedback sensor. The machine did 32 duplex prints/copies then jammed with a J4701. After clearing the jam the machine would J4701 with every duplex print/copy thereafter.
I called Kyocera support. The tech had me check the sensors and switches with U031. Was told there is a high probably the problem is coming for the Feed Image PWB. For future reference, the Feed Image PWB for the 25/3252ci is different from the Feed Image PWB for the 25/3253ci. The Feed Image PWB from the 3552ci thru 6052ci is different from the 3553ci thru 6053ci series and different from the smaller series as well. I ordered a Feed Image PWB.
When I went back I took a new Feed Image PWB and a Exit Section. I discovered the 2553ci Exit Section is the same as 2553ci Exit Section. The Exit Sections for the 3552ci thru 6052ci are the same for the 3553ci thru 6053ci series but different than the smaller series.
At the machine I installed the new Feed Image PWB and updated the firmware. The machine did duplex a few then jammed with a J4701. I took off the new Feed Image PWB and put the old one back on. I then replaced the Exit Section and tried duplexing. It duplexed a few then jammed with a J4701. I then put the new Feed image PWB and got J4701 right away. I also checked for any bent pin on all connectors with the Exit Section and the Feed Image PWB.
I called Kyocera support and explained what I have done so far. I was asked if the right side cover was bowed out. I checked and noticed the front side of the right side cover stuck out 4mm as compared to the back side that was flush. It was suggested I try a right side cover. I replaced all the original parts before I left.
I may go over there with a right side cover. I found that the right side cover is the same for the 2552ci thru 6052ci and the 2553ci thru 6053ci. I may also take fuser unit as well. However, I think that the problem being the right side cover a bit fantastic. Could be, but I don't know.
Any other thoughts or suggestions would be most welcomed. Thanks in advance.
