Good day everyone. I am working on the Kyocera TA3501i. The machine touch screen was stuck on WELCOME. I tried reloading the Firmware and replacing the HDD but that didn't work. I installed a used Main Board and WELCOME went away, however when I try to make a copy the error code F46F comes up. If I try to print an internal job, its doesn't print. I can cancel the job but the screen stays on the CANCELLING screen. I power off and on the machine and it registers a Paper misfeed. Any suggestions?
Kyocera TA3501i Error Code F46F
I've not attempted to install a used Main PWB for fear of data corruption from the HDD. Data from two different machines. Were you able to perform a U026 to restore backup data from the HDD?Net+ PDI+ @Remote -
Evil will always triumph because good is dumb.Comment
Component: CreateBox (Memory Tx). Category: ImageProcess. Crucial (no memory, invalid parameter, etc.). 1) Power Off/On, if re-occurs 2) HDD Initial in system menu (System Menu, Adjustment/Maintenance, System Initialization). Power Off/On, if re-occurs 3) Reformat HDD (Status, 10871087, 024, Start, Execute, Start). Power Off/On, if re-occurs 4) Repl HDD.
I think I'd replace the hard drive. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
What about replacing the memory ? IIRC there is 1-2gb RAM installed.
Also, what's the jam code you get ? There are some codes that relate to image processing, etc.Comment
But did you replace the HDD AFTER you swapped the Main PWB? Could have been the HDD was bad because of the main board blowing it out. Rare, but I've had it 2 or 3 times with different components.Comment
I swapped the HDD before replacing the main board.
If I am not mistaken, my original issue was a C0640 error. I swapped the HDD first then both cables. The problem remained. After swapping the HDD and cable, I replaced the main board and the machine came up. A few days later the customer said the display was stuck on WELCOME. WELCOME came up after a power outage. I tried to reload the software but the screen never moved from WELCOME. I installed another HDD and a main board always remembering to swap the EPROM. The machine came up. The touch screen however was not as clear. There were fine lines going through the screen. The machine comes to ready but when I go to make a copy, nothing happens. The screen changes like its going to copy but it never copies. When I try to print the STATUS REPORT, I get the error code F46F .Comment
