Adjust print margins
  • mdfurqan2012
    • 194
    Can we adjust print position/ print margins or leading edge and side to side registration adjustment in kyocera 5500i as we can did in Ricoh?
    Kindly help
  • fishleg
    • Mar 2009
    • 425
    Re: Adjust print margins
    034 - start position - l cassette
    also start position 3/4 - l cassette
    A little bit of a cheat really just moves the whole image over. The only way I've found to affect print jobs
    • PrintWhisperer
      • Feb 2018
      • 453
      This is the only hardware level page adjustment and it will affect your copies the same as prints, and only has about 3mm of adjustment in each direction.
      Print margins are APPLICATION controlled. Page Setup options appear in most applications for setting margins and if they do not then your application sucks.
      Only when the application sends NO PCL/PS margin commands, can the margins be set by default printer settings via FRPO.
      To determine this you will have to do a data-capture and examine the file with EscapeE to see if it has margin commands in it.
      "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
      • Horologydoc
        • Jun 2011
        • 61
        Look at U402 before you adjust the LSU in U034.
          • 22920
          I usually just look at my service manual. =^..^=
