white, dim screen problem with ecosys m2540dn, ecosys p2040dn in printer
  • trunghuynh20202020
    Technician_kyo
    • Oct 2021
    • 22
    hello all, my area has 2 ecosys m2540dn machines with white screen error and 1 ecosys p2040dn with the same error above, the machine still prints and copies normally but the screen does not show anything, please help me with solutions you know, i'm so grateful
    ecosys p2040dn white screen.jpgecosys m2540 white screen.jpgecosys m2540 white screen1.jpg
    • 22917
    Re: white, dim screen problem with ecosys m2540dn, ecosys p2040dn in printer
    Have you updated firmware? =^..^=
    • PrintWhisperer
      • Feb 2018
      • 452
      If you have installed optional languages please read the following, an error may produce your symptom:
      The number of the optional language which can be registered in the above models increases from 1 to 5.
      Accordingly, attention is required by a case.
      [Outline]
      • If the optional languages registered are less than 5, only the optional language of remaining number can be installed. -> Same as before
      • If 5 optional languages are registered and other optional language is necessary for users, uninstalling all the optional language software by the Language Uninstaller software and registering the necessary optional language software are necessary.
      -> Be sure to note [Attention] as below.
      --- By inserting a USB memory device storing the Language Uninstaller software and the necessary language software, uninstalling all the language software and registering the necessary language software are completed.
      [Attention]
      To uninstall or install the optional language, first check what the language chosen now.
      If an optional language is chosen, change it to the standard language once. After that, delete all the language software by the Language Uninstaller software and install the necessary optional language software.
      Otherwise, the following phenomenon might occur. (Refer to [Phenomenon due to the Language Uninstaller software improperly used].)
      (When the optional languages less than 5 are registered, the following phenomenon does not occur since uninstalling the language software by the Language Uninstaller software is not necessary.
      Therefore, if additionally installing the optional language software in case the optional language registered is less than 5, be sure not to store the Language Uninstaller software in a USB memory device.)
      When starting up the main unit after all the optional language software is uninstalled by the Language Uninstaller software and other language software is installed alternatively while the optional language uninstalled was chosen, the language information chosen does not exist then the phenomenon such as "The operation panel is blank", "The report is output as blank page" might occur. (Refer to [Phenomenon and recovery] in the following page for the details.)
      Good Luck!
      "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
        Technician_kyo
        • Oct 2021
        • 22
        thank you very much, i will try to run the firmware again
          Technician_kyo
          • Oct 2021
          • 22
          Good Luck!
            Technician_kyo
            • Oct 2021
            • 22
            Good Luck!
            thanks for your guidance , in my opinion this is service bulletin ref.no :com-0377(H051) note for language registration case ,my case is suspecting lcd driver ic hardware failure ,updated the new firmware version still error (intermittent error), the error disappeared after replacing PARTS PWB M PANEL ASSY SP 302S094080, I don't know if kyocera has updated service bulletin for this or not? , and has anyone encountered the same situation as me have a simple solution or not?
              • 22917
              Have you looked at System Menu/Counter > Adjustment/Maintenance > Display Brightness > ...
              if it's at 5 try lower ... like 3. =^..^=
              • PrintWhisperer
                • Feb 2018
                • 452
                  • 22917
                  Thanks, PrintWhisperer. =^..^=
                    Technician_kyo
                    • Oct 2021
                    • 22
                    Thank you very much, maybe I have to find a way to get rid of the language with some testing and follow-up because the error doesn't happen often
