I removed the main drive unit to clean the waste toner auger, due to noise, I followed the manual to the letter.
When I turn the printer on it gives me the message " close maintenance front cover" and point toward the front lower cover.
The cover is closed fine even if I activate the switch manually the message stays on.
Does this cover has more then one switch, beside the one on the right side?
Did you experience problems with this switch? To get to it do I have to take the front panel off or the right side?
I did check all the connectors on the main drive unit board, all are plugged and look fine.
