Kyocera Ecosys M6530cdn Magenta Problem
  • Rizal182
    • Jan 2022
    • 1
    Hallo Guys
    I have problem with my M6530cdn machine when i print an image through PC
    on coreldraw app
    The printing result seems to be more pink/red than the original image
    If the original image is grey on PC then the printout become pink, or the original image on PC is yellow then the printout become orange.
    I've tried to adj half tone and the colors return to normal, but when i do a manual calibration or auto calibration the problem appears again and its always appears after calibration
    I've tried to DEV CLN, drum refresh, clean the PCR, cln laser unit, cln ID sensor, but nothing change
    Does anyone have any suggestion?
    Thanks in advance
    *Sorry for my bad english
  • copier tech
    • 8095
    Re: Kyocera Ecosys M6530cdn Magenta Problem
    Originally posted by Rizal182
    Hallo Guys
    on coreldraw app
    Thanks in advance
    This is assuming you are using genuine parts & toner.
    Update the firmware & printer drums run the auto calibration again this should help.
    You may also need to calibrate your screen. It may not be a printer issue at all.
      • 22917
      I may be able to offer an opinion, if you were to attach a color sample of something like this:
      Keep in mind that the Medius is probably not any kind of production quality printer. =^..^=
      • Ropariva
        • 628
