Kyocera Ecosys M2540dn scanning issue
  • brunot
    • May 2012
    • 148
    [Misc] Kyocera Ecosys M2540dn scanning issue
    Hello everyone,
    The Kyocera Ecosys M2540dn is connected to the computer (Windows 11 Pro) via USB cable.
    Everything was working normally until last week when the Kyocera QuickScan (software for scanning) showed us an error saying, "A problem occurred during scanning!" And it just won't scan.
    The printing is working fine, but not the scanning. (See attached file.)
    I have tried removing the device software and TWAIN driver and doing a clean install, but with no luck.
    I have also tried updating the firmware of the device, but the problem persists.
    Any ideas? Thanks.
  • kuby
    • Oct 2007
    • 1370
    Had this happen to a M2540dn, that they updated their ISP. Had one that was working and ATT came out and installed a NEW modem/router and could never scan again. ATT said they did not change anything. RIGHT Don't think it is the same issue but ask anyway. Ended up using the Kyocera Print Center to get it to scan.
    • Ropariva
      • 628
      Do a fresh install on another computer or laptop. This will confirm if you have an issue with the pc or with the device. Have you tried a network connection and SMB or FTp scan?
        • 22914
        If I recall correctly there is a place in the scanning application in which you can right-click, then choose "non-secure devices". Until you make that selection it doesn't work.
        • brunot
          • May 2012
          • 148
          Today another client has encountered the same issue on a Kyocera Ecosys MA4500ix connected to the network, with software scanning: Kyocera Print Center.
          I think Kyocera Print Centre only works with a network connection.
          • brunot
            • May 2012
            • 148
            Installed on another laptop: same issue.
            Scan to Folder (SMB) tested ok, but the user wants to use a USB connection, not a network connection!
            • brunot
              • May 2012
              • 148
              I am unable to locate this option on the Kyocera QuickScan app. Can you please show me? Thanks
              • tmaged
                Owner/Service Manager
                • Oct 2008
                • 1854
                That's the problem with USB. When it's not working, there's no way to troubleshoot it.
                Hope that helps !
                -Tony
                www.dtios.com
                Become a fan on Facebook
                • Black Cloud
                  • 126
                  Try the usb connector in another computer port. It may re-establish a connection.
                  Net+ PDI+ @Remote
                  • kuby
                    • Oct 2007
                    • 1370
                    Have you tried to set it up Wireless.
                    • brunot
                      • May 2012
                      • 148
                      Wireless or network connection, Kyocera Quickscan: tested ok
                      • dalewb74
                        • Feb 2018
                        • 1104
                        throw the usb in the trash. put it on the network and let it bump. scan via usb always has issues.
