Kyocera 6635cidn error code 4600
  • surecopy
    • Mar 2018
    • 38
    Hi I work on some Kyocera copiers but have not worked on this one I see it has to do with cleaning mode just trying to see if I could get an idea what to do or look for thanks in advance
    • 22916
    Re: Kyocera 6635cidn error code 4600
    Yeah, it's a failure of the laser slit glass cleaner to complete it's cycle. It's the same mechanism on Genesis, Mebius, & Mebius II. There are several reasons why this might occur:
    I had a customer that would become irritated when the MFP tried to do it's automatic laser slit glass cleaning during a print job, displaying: "Cleaning the Laser Unit." The customer explained: "All I do is pull the power cord, and it stops that." (**genius**). Now the cleaner is not at home position, & goes into C4600. Usually you get a void line in the images too, because the cleaners block the laser slit glasses. It's simple enough to remove the consumables and loosen the laser unit screws. Lift each of the laser units (two) and rotate the cleaner drive to home the cleaner to the left. Make sure that it turns smoothly. Re-tighten the laser unit screws and re-install the consumables.
    In dirty environments the cleaner can drag. Cleaning the worm drive and lubricating it with grease can help.
    If the motor turns slowly or just will not run, the engine relay PWB may have a failing drive circuit. Temporarily home the cleaners to the left, then disconnect J26 on the engine relay PWB. The cleaner will not stall ... it won't move at all. But it also won't clean the laser slit glasses, so you'll be out more often to clean the laser slit glasses manually. (towel & glass cleaner). For the automated cleanings to resume, you'll have to replace the engine relay PWB.
    You can test the Laser Slit Glass Cleaner multiple times in the System Menu to see that it can complete several cycles.
    • Ropariva
      • 628
      • rapo_tech
        • Feb 2019
        • 114
        Usually theres problem with the pads not getting on slit glass.
        Here is a video for mod that helped me with same problem - Laser Modification.mp4 - Google Drive
        • tmaged
          Owner/Service Manager
          • Oct 2008
          • 1855
          We've tried the modifications and were never successful. We just remove the augers and clean them whenever the customer gets streaks.
          Hope that helps !
          -Tony
          www.dtios.com
          Become a fan on Facebook
